Which Enigma 2 box?
cactikid
Member
With the issues with the H7S i am on the hunt for a replacement box 4K as tv is 4k.
I did have twin sat but lost a feed and down to one.
Saorview tuner so a combo as dont think any triple tuners and might have to settle with a combo.
Most important is needs VIX images as using them for many years.
Living in Ireland sucks as UK prices with import tax can rule that out and looking foreign.
I also like internal ssd and the ability of having extra usb ports as 2 tb externally powered hdd in use also.
So far boxes been looked at
OCTAGON SF8008 4K UHD
GIGABLUE UHD TRIO 4K PRO
Might be others out there not seen yet.
If you want a good solid box with no FBC tuners then go for a AB Pulse 4K rev 2
If you want FBC tuners then Gigablue UHD 4K Pro Or Vu+ Uno SE 4K
Otagon 8008 Rev3 is the best out of the 2 you mention.
Recordings seem to be a problem now as new tech has come along and cannot use internal ssd as seem to have evolved with new generation and push in .
Are these now the norm if looking at 1 or 2tb drives.
Side usb port is handy for external hdd in case i get the other one at a later date.
Bugger the box was out of stock as not noticed no delivery date so i got refunded.
Scratching my head when one website says it has a FBC tuner ?? and can that be used with a standard quad lnb ?
Not sure if its a typo and no mention of REV 1 OR 2
Searching around Europe and other places and getting crazy prices.
4K-BOX PULSe AB 1x DVB-S2X 1x DVB-C/T2 4K UHD 2160p PVR​
Getting more confused when searching in Europe for this box listing difference tuners ?? is this a thing ??
The receiver includes a built-in DVB-S2X tuner and a second Plug & Play terrestrial/cable DVB-C/T2 tuner, which you can exchange for a DVB-S2X satellite tuner at any time.
And the other place says this .
AB PULSe 4K UHD COMBO is a 4K/UHD satellite receiver and has built-in 2 FBC DVB-S/S2/S2X tuners and one hybrid DVB-C/T/T2 tuner. It uses a LINUX operating system and is loaded with ENIGMA 2 software.
It can be used as a satellite receiver to watch free and encrypted satellite programs. By installing a dedicated application, it can also be used as a receiver for watching Internet TV (IPTV).
The receivers we offer come with a 2-year factory warranty.
Only shows 1 sat input on photo and the usual DVB-C/T/T2 tuner PORT.
With all the crap on foreign countries i said bite the bullet and buy from WOS.
Now its only the other bits to pay when it lands and less hair pulling.
