Virgin Media 360 Box
Krusty
Member
What are the real advantages of getting a Virgin Media 360 box, I have yet to change as I dont wish to lose all my recordings.
advantages
Startover — on supported channels you can restart a programme that's already begun.
Better integration with streaming services — Netflix, Disney+, Paramount+, BBC iPlayer, ITVX and others sit alongside normal TV rather than feeling like separate additions.
Better multiroom experience if you have additional boxes, with recordings and viewing progress accessible around the house.
The big downside in your case​
Your existing V6 recordings will be deleted when you convert to 360. Virgin explicitly confirms that recordings and settings cannot be transferred.
And interestingly, if you've got a V6, you don't necessarily receive a fundamentally better piece of hardware. Virgin can convert your existing V6 into a 360 by changing its software and sending you the 360 remote.
Don't do it mate, I did & wish I hadn't.
Changed over 2 in the house a few months ago & one of the boxes already failed (small sample size admittedly but off to a bad start with a new box). The multiroom experience doesn't work well for me, my wife's recordings clutter it up & I have to go searching for anything I've recorded, frustrating. Start-Up screen isn't last channel watched goes to home screen, frustrating. Subtitles: 6 key presses to turn off or on, frustrating.
On Demand is probably the (only) saving grace, easier/faster to navigate. They've renamed the 'last channel' button on the remote to 'tv', frustrating (for me anyway I keep forgetting which button does it, labelling it last channel kinda gave me a clue)
HH.
HH.
Hmmm, on that post " H " I think I will still hang on to my V6, if they do update it with new firmware, I wonder if my recordings will disappear ??
Happy to hear how bad an experience you had @HappyH not in a bad way, i have been resisting for about a year now and mrs is falling in line with Virmin , i've already told virmin i will not upgrade anything until i get a better upload speed.
