Slimbox Rom Install on a Transpeed X8 using PhoenixCARD SD Card preparation.
Ferret
Administrator
Staff member
Administrator
MicroSD card flashing tool usd to flash images generated using Allwinner Technology's source code. The tool creates bootable microSD cards and NAND flashing microSD cards.
Screenshot-PhoenixCard-Main
Instructions:
CAUTION!! This tool can reimage (erase) a drive if used incorrectly. Verify the drive being flashed and
as a precaution, remove any unnessecary USB drives prior to the burn process.
1 - Launch App and select the firmware to flash to the microSD card.
2 - Select the write mode, Product creates microSD card that flashes image to module NAND and Startup creates a bootable microSD card.
3 - Insert USB/MicroSD adapter and verify USB/MicroSD adapter matches the drive letter selected in PhoenixCard.
4 - Select burn once ready to create the MicroSD card.
Phoneonix card and Formatter downloads
Nice one ferret, I bought one of these bad boys 2 months ago, the old fire tv box was playing up, it' fast. once you clear the
russian apps clutter lol. (y)
