Privazer 4.0.126
alimac
PrivaZer is a free PC cleaner and privacy tool for Microsoft® Windows®. The software allows users to remove additional occupied space from a hard drive partition, but it can also prevent recovery of sensitive files by using several advanced overwriting algorithms. Before removing anything, you can scan, preview the results and choose what data to keep or remove. Additionally, the software can be used in two different ways: basic or advanced user mode. The basic mode performs most actions automatically based on a preset configuration while the advanced user mode gives you more control over the software. Currently, the program is available as an installer and portable version.
Free version
https://privazer.com/en/PrivaZer_free.exe
Portable
https://privazer.com/en/PrivaZer.exe
