PCB Repairs – Start With Diagnosis, Not the Soldering Iron
When something electronic stops working, it can be tempting to immediately get the soldering iron out and start replacing components.But with PCB repair, one of the most important skills is actually fault finding.
Before touching the board, start with a good visual inspection.
Look for things such as:
- Burnt or discoloured components
- Bulging or leaking capacitors
- Cracked solder joints
- Broken connectors
- Corrosion or liquid damage
- Damaged PCB tracks
- Components that have obviously overheated
Next Comes the Multimeter
A digital multimeter is probably one of the most useful tools for PCB repair.With the equipment disconnected from the mains, basic checks can include:
- Testing fuses for continuity
- Looking for short circuits
- Checking PCB tracks
- Testing switches and connectors
- Checking resistors
- Testing diodes
- Looking for shorts across power rails
Don't Replace Parts Just Because They Look Suspicious
A component looking slightly different doesn't necessarily mean it has failed.Likewise, a failed component may look absolutely perfect.
That's why a good repair usually follows the process:
Inspect → Test → Diagnose → Repair → Test again
rather than:
Guess → Replace parts → Hope it works.
Soldering Is Only Part of PCB Repair
Being able to make a neat solder joint is important, but PCB repair involves several other skills:Basic level: Through-hole components, connectors, switches, fuses and simple continuity testing.
Intermediate level: Capacitors, diodes, transistors, voltage regulators, damaged tracks and basic power-supply diagnosis.
Advanced level: Surface-mount components, IC replacement, hot-air rework, trace repair and more complicated circuit diagnosis.
The important thing is to build those skills gradually.
And one rule worth remembering:
Never practise your first repair technique on something valuable.
Old or scrap circuit boards are ideal for learning component removal, soldering and track repair without worrying about destroying something you actually need.
PCB repair isn't really about swapping components — it's about working out why the circuit isn't working in the first place.
