LG Smart TV Hidden Features (Service Menu & Codes)
Oggiman
Moderator
Staff member
Moderator
LG TV Hidden Features — LG secret menu (Service Menu & Codes) ** Use Carefully at your own risk
To access the secret menu on your LG smart TV, you can use the following codes and methods:
Using the Original Remote: Press and hold the MENU button on your LG TV and the Menu button on your original remote. Release both buttons when the menu shows on your LG TV screen. If prompted, enter the password 0000, 8741, 8878, 8743, 0413, or 7777.
Using the LG Magic Remote:
Press the INPUT button on the remote, then enter 3195 to bring up the service menu. If that doesn't work, press INPUT again and hold the MENU button until prompted for a passcode.
Using a Smartphone App: Download an IR Blaster compatible app on your Android smartphone, select 'LG TV' as your target device, and tap on the 'IN START' or 'EZ ADJUST' button within the app. Point your smartphone towards your LG TV’s IR sensor and tap on either of these buttons again when prompted.
These methods will allow you to access the secret menu and make adjustments to your TV settings.
LG secret menus allow you to access various settings that are not readily available to casual users. You can use them to perform factory resets, fine-tune HDMI input settings, or change network configurations.
While the secret or service menus in LG TVs look slightly different depending on the TV model and year of manufacture, they generally offer the same type of settings and adjustments.
Here are more settings that you can change in the secret menu:
  • Adjust network-related settings such as DNS and IP address.
  • Run hardware diagnostics to check if the set has any hardware problems.
  • Change HDMI input configuration settings such as deep colour and colour space.
  • Access special service options used by technicians.
  • Update the TV's firmware.
  • Adjust calibration settings such as white balance and colour temperature.
Before you adjust your LG TV's secret menu, note down or take a photo of the original settings. If you mess up with anything or encounter problems, you can refer to the initial settings.
