FuryBiss 6.5
Update Features:
Fixed crashes on VU+ devices
Fixed crashes caused by pressing the OK button on the feed screen
Feeds now open in 0 seconds, except for OpenVix images which take 1 second
Secured server connection
Improved Emu startup speed
Fixed device model recognition
You must choose the path to save the codes as shown in the images
Note: Feeds will appear in the plugins when available, and a pop-up notification will appear.
If you encounter a problem during installation, delete any previous version higher than the released version and reinstall the script
wget -q "--no-check-certificate" https://raw.githubusercontent.com/islam-2412/FuryBiss/refs/heads/main/fury/installer.sh -O - | /bin/sh
