DOWNLOAD Enigma2 Control Manager
Blade
Administrator
Administrator
iet5 wrote
Enigma2 Control Manager has been developed from the ground up as a comprehensive and professional solution for managing and programming Linux / Enigma2-based satellite receivers such as Dreambox, Vu+, Gigablue, Octagon, and others.
The project was created to address the common shortcomings of traditional management tools, including slow file transfers, interface freezes, and unstable connections, while providing a unified workspace that brings together all essential tools required by both end users and developers in a single application.
Instead of switching between multiple programs for file management, command execution, and channel editing, Enigma2 Control Manager integrates three fully synchronized modules: FTP Manager, Channels Manager, and Telnet Terminal, delivering a faster, simpler, and more efficient receiver management experience.
Technical Architecture & Performance
  • Developed entirely in C using Visual Studio and the native Win32 API.
  • Extremely lightweight, with a size of approximately 1 MB.
  • Instant startup and responsive performance with minimal CPU and memory usage.
  • Fully Portable application requiring no installation and no additional dependencies such as .NET Framework or Java.
  • Utilizes the built-in WinINet library for stable and reliable network communication.
  • Stores settings and transfer history in lightweight INI files instead of complex databases for maximum speed and simplicity.
Module 1: Receiver FTP
An advanced file management module designed for fast and efficient file transfers between the PC and the receiver.
Key Features
  • Dual-pane interface for convenient upload and download operations.
  • Drag-and-drop file transfer support.
  • Intelligent synchronized navigation (Lockstep Navigation) between local and remote directories.
  • Full support for displaying Arabic filenames correctly (UTF-8 Fix).
  • Support for:
    • FTP
    • FTPS
    • SCP / SSH
  • Built-in Keep-Alive mechanism to prevent connection timeouts.
  • Compress files and folders into ZIP archives before uploading for faster transfers.
  • Local ZIP extraction support.
  • Smart detection of old backup files (.bak) with optional cleanup recommendations.
  • Direct editing of receiver files with automatic upload after saving.
  • Support for external editors such as Notepad++.
  • Integrated CHMOD permission management from the context menu.
  • Instant file and folder search using Ctrl+F.
  • Folder comparison with visual highlighting of missing or modified files.
Connection Management (Site Manager)
  • Store an unlimited number of receiver profiles.
  • Save:
    • IP Address
    • Username
    • Password
    • Port
  • Quick connection via double-click.
  • No automatic connections are made when the application starts.
File Management
  • Upload and download files and directories.
  • Protection against accidental file overwrites.
  • Displays old and new file sizes before replacement.
  • Quick-access context menu for common operations.
  • Supports commonly used CHMOD values such as:
    • 755
    • 775
    • 777
    • 644
    • 666
    • 600
Module 2: Channels Manager
A dedicated module for managing channels and bouquets without the need for third-party applications.
Main Features
Import and export channel files.
  • Supports:
    • lamedb
    • userbouquet
    • satellites.xml
  • Picon management and upload.
  • Automatic removal of unused Picons to save storage space.
  • Instant channel reload (Service List Reload) without rebooting the receiver.
  • Safe Restart GUI function for reloading the Enigma2 interface.
Smart Options
Select Files to Receive
Allows the user to choose exactly which files should be downloaded:
  • Channels only
  • Satellites and transponders only
  • All files
Auto Reload Settings Enigma2
Automatically reloads channel settings on the receiver immediately after uploading, without requiring a restart.
Remove Unused Bouquets
Deletes obsolete or unused bouquet files from the receiver to keep the system organized.
Upload Picons
Automatically uploads channel Picons together with channel files.
Safe User Interface
  • Custom Owner-Draw buttons.
  • Modern visual effects.
  • Confirmation dialogs for sensitive operations.
  • Ability to run the Channels module independently using:
NewFtp.exe /channels
Module 3: Telnet Terminal
A high-performance integrated terminal that eliminates the need for external Telnet applications.
Professional Command History System
  • Stores commands in an external file (cmd_history.txt).
  • Prevents saving empty or duplicate commands.
  • Command navigation using ↑ and ↓ arrow keys.
  • F7 command history popup list.
  • TAB-based command auto-completion.
  • Cursor locking within the active input line to prevent accidental modification of previous output.
Additional Features
  • Fast and direct receiver connection.
  • Full copy and paste support.
  • Ability to run the Telnet module independently using:
NewFtp.exe /telnet
  • Easy execution of system commands and package management tasks.
  • Multi-line command support.
Security & Data Protection
Secure Communication
  • Full SCP / SSH support through port 22.
  • Encrypted transfer of sensitive files and data.
Password Protection
  • Uses the official Windows Crypt32 library.
  • Passwords are encrypted before being stored in configuration files.
  • Decryption occurs only in memory during active connections.
  • Passwords are never displayed or stored as plain text.
Conclusion
provides a complete, lightweight, and high-performance environment that combines:
  • Advanced file management and networking.
  • Channel and bouquet editing and transfer.
  • Direct receiver control through Telnet.
  • Strong security with encrypted communications.
DOWNLOAD
