Docker or Direct Installation on Linux – Which Is Better?
Docker has become extremely popular for running services such as Home Assistant, Pi-hole, media servers and web applications. Instead of installing everything directly onto Linux, each service runs inside its own container with its dependencies separated from the rest of the system.
Docker can make services easier to move, update and restore. If an update causes problems, it is often possible to return to the previous container image. It can also prevent conflicting software dependencies.
However, Docker introduces another layer to manage. Volumes, networking, permissions and container configuration can be confusing, especially when diagnosing a problem. For a single service on a Raspberry Pi or home server, installing it directly might be simpler and use slightly fewer resources.
Which approach do you prefer?
Do you run your services in Docker containers, install them directly onto Linux, or use a mixture of both?
