MILPITAS, CA, October 21, 2026 – CORSAIR® (Nasdaq: CRSR) is proud to announce the launch of the upgraded RM1200e with Platinum-certified efficiency, the new flagship of the best-selling RMe power supply family. It joins the latest generation of the RMe PSU series as a high-powered option for system builders who value the reliability and features of the RMe series.
The RM1200e is also the first CORSAIR power supply to feature a native 12V-2×6 connection with PinProtect per-pin overcurrent protection (OCP). Designed to help protect high-end graphics cards, PinProtect monitors the on flowing through each power pin in real time and reduces power to the connection if the current exceeds a preset threshold for too long, triggering a protective GPU shutdown. If this occurs, users should completely power down their system, check for loose or improperly seated connections, and only restart once the connections are secure. This helps reduce the risk of damage caused by excessive current.
CORSAIR Launches the RM1200e Power Supply with Built-in PinProtect GPU Overcurrent Protection and Platinum-certified Efficiency | CORSAIR Newsroom
