Audacity 3.7.9
alimac
Audacity is a free audio editor. You can record sounds, play sounds, import and export WAV, AIFF, and MP3 files, and more. Use it to edit your sounds using Cut, Copy and Paste (with unlimited Undo), mix tracks together, or apply effects to your recordings. Audacity is a software that allows you to record andplay sounds. It also has a built-in amplitude envelope editor, a customizable spectrogram mode and a frequency analysis window for audio analysis applications. Built-in effects include Bass Boost, Wahwah, and Noise Removal, and it also supports VST plug-in effects.
Release Audacity 3.7.9 · audacity/audacity
Audacity 4.0 completely redesigns the program's interface, brings more clip management and recording options, and more.
Audacity has just released version 4.0, and this is one of the biggest updates the popular free audio editor has received in years. The biggest change is that the new version rebuilds the program’s interface on Qt. On top of that, Audacity also got a new editing model, and a bunch of new improvements.
Note: Audacity 4.0 is available now for Windows, macOS and Linux. The update is still free and open source, just like previous versions. Keep in mind, this is the separate release from the old Audacity version 3.7.9, so you'll have to install it separately, instead of updating it through the program's settings.
Audacity ® | Downloads
