Advanced Renamer 4.25
alimac
Advanced Renamer is a free batch rename utility with multiple methods for renaming multiple files and folders at once. By configuring renaming methods the names can be manipulated in various ways. The 14 different methods enable you to change the names, attributes, and timestamps of files in one go. The files can also be copied or moved to new locations based on information in the files. With Advanced Renamer you can construct new file names by adding, removing, replacing, changing case, or giving the file a brand-new name based on known information about the file. Advanced Renamer allows the use of regular expressions and wildcards. Before performing the operations on the files, you can verify that the output will be correct and if you perform the rename and regret it, you can undo the complete batch. With Advanced Renamer you can change the names of your favourite music files to more suitable names using the built-in ID3 tags. This mass file renamer is a great utility for organising digital pictures for both professionals and beginners with EXIF support.
64Bit Installer
https://www.advancedrenamer.com/down/win/advanced_renamer_setup_4_25.exe
64Bit Portable
https://www.advancedrenamer.com/down/win/advanced_renamer_portable_4_25.zip
